Old 04-13-2021, 10:45 AM   #1
the-rodster
Default 1934 coupe - how do you attach hinges to repro trunk?
No holes are drilled, but what goes in the whole once drilled?
Rivet nuts?
Caged nuts?
Drilled and tapped plate?
What did Henry use?
Thanks,
Rich
the-rodster is offline   Reply With Quote
Old 04-13-2021, 11:14 AM   #2
JSeery
JSeery's Avatar
Default Re: 1934 coupe - how do you attach hinges to repro trunk?
Not the best photo, but should give you the info on how the originals were mounted. I would use a nut plate (the kind that are somewhat of a pop-rivet). You could check with Kerl Wescott, I would guess that he deals with this frequently.
Sent you a Private Message.
Old 04-13-2021, 11:43 AM   #3
JSeery
JSeery's Avatar
This type of setup was what I was thinking. Note: Not endorsing this brand, don't know anything about it, just found the photo online.
Old 04-13-2021, 01:52 PM   #4
Karl Wescott
Karl Wescott's Avatar
Originally the deck lid inner panel had "D" nuts riveted on.
If the outer panel is not on the lid then simply screw the hinges to the inner panel with nuts inside. Get everything fit including the outer panel and the latch, then weld the nuts in place.
If the outer panel is on you can use a "nutsert" type clinch nut similar to what JSeery recommended. Or you can make nut plate for each pair of holes and fish them into place and hold with epoxy or spot weld.
Karl Wescott is offline   Reply With Quote
