Old 03-28-2021, 07:45 AM   #1
Newby
Default 1935 16” spoked rims
I have chance to buy a set of wide whites, bias looking radials with tubes. I want to put them on ‘35 16” spoked rims. The problem is, the fronts are 600-16 ( which is ok), but the rears are 750-16. Can I put 750s on a 4” rim? Or did ‘35 rims come in different widths? Thank you to all that reply!
Newby is offline   Reply With Quote
Old 03-28-2021, 12:01 PM   #2
deuce lover
deuce lover's Avatar
Default Re: 1935 16” spoked rims
'35 spoke wheels only came in 4" widths. There is a 16 " Kelsey that is 4.5 " wide but those are next to impossible to find.
deuce lover is offline   Reply With Quote
Old 03-28-2021, 11:03 PM   #3
Talkwrench
Talkwrench's Avatar
Guys have been putting 7.50x16 on 4" rims.
"Came too close to dying to stop living now!"
Talkwrench is offline   Reply With Quote
Old 03-29-2021, 08:21 AM   #4
ct1932ford
ct1932ford's Avatar
No issues at all!
A man should do what he thinks best! "The Duke"
ct1932ford is offline   Reply With Quote
Old 03-29-2021, 08:32 AM   #5
tubman
tubman's Avatar
Yep, been done many times. I have seen a couple where the guys stepped up and had the wire wheel widened. I really like that look.
Old 03-29-2021, 02:02 PM   #6
Charlie Stephens
Be sure to check the date code on the tires before you go too far.
Charlie Stephens
Old 04-01-2021, 11:00 AM   #7
Fred A
Fred A's Avatar
At a swap meet the 4.5" Kelsey looks mostly like any other 4". "Impossible" is a bit strong. The 7.50 still looks pinched on 4.5" but may be safer on the road. I'm moving up to 18" now that better tires are available. Fifteen years ago clean 17" or 18" Ford wheels were very cheap because of the poor tire choices. 16"s had been king for decades and sent the value of 1935 and Kelsey 16"s way up. Now seems like a glut out west. Love that tall tire look! Fred A
Fred A is offline   Reply With Quote
Old 04-01-2021, 09:18 PM   #8
JM 35 Sedan
JM 35 Sedan's Avatar
I've had a set of Diamondback (smoothed blackwall Yokohama LT radials) 750 x 16's, on stock '35, 4" wide spoke wheels for 15 years. These tires and wheels have been on my '35 fordor sedan on many trips that I've taken all over this country, including a 7,200 cross-country tour in 2013, with no problems whatsoever. Before buying these tires, I spoke with the folks at Diamondback, and they assured me these tires would work fine on my 4" wide wheels.
John
Old 04-02-2021, 02:46 AM   #9
V8COOPMAN
V8COOPMAN's Avatar
The 7.50 X 16s on 4"-wide '35 spoke wheels that "JM 35 Sedan" makes reference to just above. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 04-04-2021, 01:59 PM   #10
franksford
are you running tubes in these tires
Frank
franksford is offline   Reply With Quote
Old 04-04-2021, 08:54 PM   #11
JM 35 Sedan
Frank
If you are referring to my 35 fordor sedan with 7.50 x 16 radial tires on the rear, the answer is yes, they have tubes designed to be used in radial tires..
John
Old 04-05-2021, 12:03 AM   #12
bluardun
bluardun's Avatar
Very adviseable to run tubes in early wheels. The rims do not have a "safety bead". Under low air pressure the tire can slide or fall off the rim.
bluardun is offline   Reply With Quote
Old 04-06-2021, 07:09 AM   #13
Yoyodyne
Yoyodyne's Avatar
What brand, and where do you buy them?
Yoyodyne is offline   Reply With Quote
Old 04-06-2021, 08:43 AM   #14
JM 35 Sedan
The tire dealer in my town recommend a local Ag Industrial Supply dealer nearby for the tubes required for radial tires and the plastic valve stem spacers also required on my original '35 wire wheels. This was ~ 15 years ago, so I don't recall the brand name they carried at that time.
PS... Here's the contact info for the AG Industrial store I mentioned above:
AG Industrial Inc.
50 N. Greenmont Rd.
Rising Sun, MD 21911
(410) 658-5568
John
