I have chance to buy a set of wide whites, bias looking radials with tubes. I want to put them on ‘35 16” spoked rims. The problem is, the fronts are 600-16 ( which is ok), but the rears are 750-16. Can I put 750s on a 4” rim? Or did ‘35 rims come in different widths? Thank you to all that reply!
'35 spoke wheels only came in 4" widths. There is a 16 " Kelsey that is 4.5 " wide but those are next to impossible to find.
Guys have been putting 7.50x16 on 4" rims.
"Came too close to dying to stop living now!" |
No issues at all!
A man should do what he thinks best! "The Duke" |
Yep, been done many times. I have seen a couple where the guys stepped up and had the wire wheel widened. I really like that look.
Charlie Stephens |
At a swap meet the 4.5" Kelsey looks mostly like any other 4". "Impossible" is a bit strong. The 7.50 still looks pinched on 4.5" but may be safer on the road. I'm moving up to 18" now that better tires are available. Fifteen years ago clean 17" or 18" Ford wheels were very cheap because of the poor tire choices. 16"s had been king for decades and sent the value of 1935 and Kelsey 16"s way up. Now seems like a glut out west. Love that tall tire look! Fred A
I've had a set of Diamondback (smoothed blackwall Yokohama LT radials) 750 x 16's, on stock '35, 4" wide spoke wheels for 15 years. These tires and wheels have been on my '35 fordor sedan on many trips that I've taken all over this country, including a 7,200 cross-country tour in 2013, with no problems whatsoever. Before buying these tires, I spoke with the folks at Diamondback, and they assured me these tires would work fine on my 4" wide wheels.
#9 | |
The 7.50 X 16s on 4"-wide '35 spoke wheels that "JM 35 Sedan" makes reference to just above. DD |
are you running tubes in these tires
Frank |
If you are referring to my 35 fordor sedan with 7.50 x 16 radial tires on the rear, the answer is yes, they have tubes designed to be used in radial tires..
Very adviseable to run tubes in early wheels. The rims do not have a "safety bead". Under low air pressure the tire can slide or fall off the rim.
#13 |
#14 |
The tire dealer in my town recommend a local Ag Industrial Supply dealer nearby for the tubes required for radial tires and the plastic valve stem spacers also required on my original '35 wire wheels. This was ~ 15 years ago, so I don't recall the brand name they carried at that time.
PS... Here's the contact info for the AG Industrial store I mentioned above: AG Industrial Inc. 50 N. Greenmont Rd. Rising Sun, MD 21911 (410) 658-5568
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 04-08-2021 at 10:37 PM. |
