Old 03-19-2021, 08:52 PM   #1
JD-OHIO
JD-OHIO's Avatar
Default Gas tank shutoff valve
I am going to replace the gas shutoff valve on my 31 s/w town sedan with indented firewall. What is the recommended sealant to use on the threads where it screws into the outlet of the gas tank?
JD-OHIO is offline   Reply With Quote
Old 03-19-2021, 10:10 PM   #2
700rpm
700rpm's Avatar
Default Re: Gas tank shutoff valve
... oops. wrong thread.
Ray Horton, Portland, OR
Old 03-20-2021, 07:01 AM   #3
Slowmotoring
Slowmotoring's Avatar
I would use gasoila. You can get it at tractor supply.
Good things take time
Slowmotoring is offline   Reply With Quote
Old 03-20-2021, 10:48 AM   #4
JayJay
I use Permatex 59214 Thread Sealant. No reason for the "High Temperature", it was what was available at my local auto parts store. It has worked well, I had one shutoff valve that was leaking and it sealed it up fine. I keep the tank dry for at least 24 hours after screwing in the valve to let the sealant have a chance to set. I have not had luck with so-called "teflon tape" in gasoline applications, the gasoline seems to dissolve the tape.
JayJay
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
JayJay is offline   Reply With Quote
Old 03-20-2021, 10:53 AM   #5
katy
katy's Avatar
Originally Posted by JayJay View Post
I use Permatex 59214 Thread Sealant. JayJay
Is that the stuf w/teflon in it?
Old 03-20-2021, 10:59 AM   #6
JayJay
I don't know about "the" stuff, but yes, it does have teflon (PTFE) in it. Here's a link to the product data sheet. I'm not saying it's the "best", I'm saying it's what I've used, it's readily available and works well for me.
I suspect that some flavor of Locktite would also work, but Locktite is a different product - polymethyl methacrylate compound, aka Super Glue. Not typically used on tapered fittings like the gas valve.
JayJay
JayJay
Old 03-20-2021, 11:56 AM   #7
DHZIEMAN
I use Permatex! Never had a problem. However had problems with new petcocks not being of quality and them leaking! Sad situation on some parts and in this case a safety issue.
DHZIEMAN is offline   Reply With Quote
