Old 11-14-2020, 12:52 PM   #1
Conaway2
Conaway2's Avatar
Default Generator Field Coil Insulation
I’m rebuilding a stock A generator and am replacing the coils because the cloth (?) insulation has deteriorated and is falling off. The coils themselves seem fine - continuity tests indicate no broken windings.
if I decided to simply re-insulate the original coils, what should I use ? They appear to have been originally wrapped with some sort of cloth friction tape.
Thanks - Jim
Conaway2 is offline   Reply With Quote
Old 11-14-2020, 02:56 PM   #2
KR500
KR500's Avatar
Default Re: Generator Field Coil Insulation
There are a few different paper tapes that are used in the rebuilder's stock. I have used the 1/2 inch and 3/4 size with success. If you are sure each coil is not shorted and has continuity, great. Wrap the coils and secure the ends, after which coat or spray with an insulating coating such as McMaster Carr carries. I use an expanding tool inside the coils pressing them firmly against the generator interior, and then securing the field pole screws tightly with an impactor screw bit.
KR500 is offline   Reply With Quote
