Old 09-24-2020, 07:07 PM   #1
marko
Default steer me in the right direction
I have a 1950 ford f1. is it possible to put a 1936 steering wheel on it w/out to many cuss words?
marko is offline   Reply With Quote
Old 09-24-2020, 08:23 PM   #2
JSeery
JSeery's Avatar
Default Re: steer me in the right direction
No, the steering shaft ends changed from a tapper to a spline.
Old 09-25-2020, 07:48 AM   #3
marko
darn. so there is no reproduction steering wheels out there that would fit?
Old 09-25-2020, 08:08 AM   #4
19Fordy
19Fordy's Avatar
marko, Give Limeworks a call. They make great products.
https://www.limeworksspeedshop.com/
Old 09-25-2020, 08:27 AM   #5
JSeery
JSeery's Avatar
I think there are reproductions that will work, just not an original.
Old 09-29-2020, 06:54 AM   #6
Frank Miller
Frank Miller's Avatar
Cut and weld a new end on the steering shaft. I've turnd down one shaft and bored ot the other to make a slip fit and drill hole to plug weld one end while welding the circumference of the other. I suppose you could cut opposing notches to make a positive lock fit and then weld. Make sure the shaft is set so it puts the steering wheel at the top when wheels are straight ahead.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
