Old 07-16-2020, 02:39 PM   #1
603Huckster
Question Spark plug gap
Sorry if this has been discussed, I ran a search and didn't find anything. The "Ford Model 'A' Instruction Book" states the plugs should be gapped to .027 and Les Andrews says .035. I have found a few mentions in other threads of making sure their plugs were gapped to .035. My question is, why the discrepancy and which is correct?
603Huckster is offline   Reply With Quote
Old 07-16-2020, 02:56 PM   #2
WHN
Default Re: Spark plug gap
60 years of Model A’s, gap of .035 never used anything different.
This has been talked about many, many times.
Enjoy.
WHN is offline   Reply With Quote
Old 07-16-2020, 03:28 PM   #3
Purdy Swoft
Purdy Swoft's Avatar
I agree !! I think that early in 28 the spark plug gap was was .027 . Henry later decided that a wider gap was better . Les is correct .
Old 07-16-2020, 06:17 PM   #4
Patrick L.
Patrick L.'s Avatar
A sparkler should spark at either setting or anything in between.
The less gap, less chance of high speed misfire
More gap, idle/ low speed will be better
Old 07-16-2020, 09:25 PM   #5
McMimmcs
McMimmcs's Avatar
This gentleman said it all ! You can take his reply to the bank!
McMimmcs is offline   Reply With Quote
Old 07-17-2020, 05:29 AM   #6
Werner
Werner's Avatar
Guten Morgen,
modern spark plugs with for example Iridium electrodes tolerate a significantly larger contact distance.
(I drive the NGK 5 EiX with 0.35 ".)
Beste Gruesse aus Deutschland,
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 07-17-2020, 09:25 AM   #7
603Huckster
Thanks for the responses!
Old 07-17-2020, 09:28 AM   #8
Patrick L.
Patrick L.'s Avatar
Gentleman ! What a complement ! I think my friends would disagree though.
