#1 |
My crank hole in the radiator shell and the guide doesn't line up with the front pulley. Not sure where to start trying to make everything line up. Antone run across this problem?
#2 |
A common issue. I would start with trying to adjust the front motor mount by tightening the nut to bring it down or loosening it to bring it up. Thats if you have a stock mount with correct parts.
"The more things change, the more they stay the same." |
#3 |
Also check the rear motor mounts.
#4 |
