Old 06-08-2020, 04:42 PM   #1
Digger
Digger's Avatar
Default Suggestions for rattle can base color 34 woodgraining?
I used to be way into woodgraining, now I am lazy, but want to do the top “‘dash” strip in my Model A pick up.
Any suggestions for rattle can brand and color that is close to the original 1934 base color? Thanks
Digger is offline   Reply With Quote
Old 06-08-2020, 07:42 PM   #2
koates
Default Re: Suggestions for rattle can base color 34 woodgraining?
A medium shade maroon colour is what I have noticed on the backside of the 1934 dash panels. Regards, Kevin.
koates is offline   Reply With Quote
Old 06-09-2020, 05:44 AM   #3
big job
big job's Avatar
Red oxide rattle primer can first, next thinned flat black cheap acid brush > now scratch the
black with brush your design, let dry and lightly go over with fine scotch bright then
clear coat. I wish I could show you, but I can not get pictures out of this stupid phone.
I read to plug phone with UBS cord to the PC ok nothing happens?? sam
big job is offline   Reply With Quote
Old 06-09-2020, 06:09 AM   #4
PeteVS
PeteVS's Avatar
What kind of phone do you have? I have an iPhone and after I take pictures, they appear in the Photos app on my MAC. I simply drag them from the Photos app into a folder on my desktop and from there, I can post them online. (I usually have to shrink the image size so FordBarn will add them to my post.) (Also, if you're not using Apple stuff, I'm of absolutely no help.)
Don't never get rid of nuthin!
PeteVS is offline   Reply With Quote
Old 06-09-2020, 06:26 AM   #5
37 Cab
37 Cab's Avatar
Big Job.. If I just want a few pictures from my phone and my computer is not close, I just email them to myself then save them when I am on the computer.
Tommy
37 Cab is offline   Reply With Quote
Old 06-09-2020, 08:24 AM   #6
tubman
tubman's Avatar
This is what I do as well. Never a problem.
Old 06-09-2020, 09:54 AM   #7
JSeery
JSeery's Avatar
Using the USB connection you need to find the phone files, then find the file containing the photos, then move the photos you want over to a file on your computer. I would really encourage you to learn how to do this and back up your photos often. One phone malfunction and they are all gone! I am sure there is information online that details how to do this for your model phone.
Old 06-09-2020, 10:53 AM   #8
Digger
Digger's Avatar
I have the training wheels and inks, just looking for the base color idea, and the rust co.ored primer may be perfect
Old 06-09-2020, 11:04 AM   #9
Digger
Digger's Avatar
“graining wheels”....not “training wheels”!! ��
Old 06-10-2020, 05:44 AM   #10
big job
big job's Avatar
Thanks; what Tubman said is what I use to do, but 'that' don't work no more either, which
that was easy. Back to the subject- you can also use sharpies for details but the course
acid cheap brush works best. Keep in mind real wood has blemishes, not picture perfect
not like sign painting. Let dry overnight and the clear coat is the developer..sam
Old 06-10-2020, 12:27 PM   #11
95476
95476's Avatar
Rustoleum Red Automotive Primer, black printers ink, brown printers ink, spray clear over it.
You can layer it you get the effect you want. Follow the directions on the can about recoating times. If you recoat too soon it can lift.
I have even used Minwax wood stain (mahogany) as a color.
Thin with mineral spirits so it won't lift the primer.
95476 is offline   Reply With Quote
Old 06-10-2020, 10:22 PM   #12
Digger
Digger's Avatar
Going to use ACE red primer as the base coat, and the ‘34 Grain It Technologies walnut burl plate, will send photo when done
File Type: jpg 857B2833-BCB8-45AD-83E6-303566A28018.jpg (52.4 KB, 62 views)
Old 06-11-2020, 05:49 AM   #13
big job
big job's Avatar
Thats what I'm talking about ....
Old 06-11-2020, 10:42 PM   #14
Karl
Karl's Avatar
I used the Grain-It Burl plate . Because they can't ship spray cans internationally I matched the base coat off their colour charts and got the dash sprayed at a paint shop After I had done it all I realized I had not done the glove box hinge. I used red oxide primer as a base coat and looks exactly the same as the matched base coat at a fraction of the cost -Karl
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me.
Karl is offline   Reply With Quote
Old 07-11-2020, 09:40 PM   #15
Digger
Digger's Avatar
Here is result using the Ace primer as base color
File Type: jpg 65FD7F5E-9AF3-43AB-AA1F-02E4C8A21002.jpg (104.6 KB, 60 views)
File Type: jpg 8B6F5E61-2CDD-4957-AC5C-BC03FEB62D06.jpg (63.8 KB, 52 views)
Old 07-12-2020, 06:13 AM   #16
flathead48
Looks real good well done
flathead48 is offline   Reply With Quote
