Old 05-23-2020, 10:25 PM   #1
fred93
fred93's Avatar
Default Engine oil level question
I changed the oil on a 29 Tudor.
Les Andrews Handbook states that it will take 4-1/2 quarts when changing the oil.
I put in a little over 4 quarts and the dip stick shows about 3/16" over the full mark.
Question is: Do I add another 1/2 quart and remark the dip stick? OR what?
Why is there never enough time to do it right, but always enough time to do it over!!!
fred93 is offline   Reply With Quote
Old 05-23-2020, 10:35 PM   #2
28tudorsedan
28tudorsedan's Avatar
Default Re: Engine oil level question
Could possibly have some sludge build up in there hence the reason at 4 quarts your already over the mark I did my oil change last week at 4.5q I was right on the full line.
28tudorsedan is offline   Reply With Quote
Old 05-23-2020, 11:58 PM   #3
Aok
Aok's Avatar
There is some oil that stays in the pan. Some one can explain it better then me.
I usually put in 4 qts on a oil change.
Aok is offline   Reply With Quote
Old 05-23-2020, 11:58 PM   #4
Jim/GA
Jim/GA's Avatar
No, do not remark the dip stick and don't add any more oil. In fact, try to take some oil out.
If you overfill the engine, the rear main seal will usually leak more.
Jim Cannon
Former MAFCA Technical Director
"Spread the Joy! Have a Model A day!"
Jim/GA is offline   Reply With Quote
Old 05-24-2020, 06:48 AM   #5
shew01
shew01's Avatar
I never thought about sludge potentially taking up space in the oil pan and altering the amount of oil required for a refill. My car’s engine was rebuilt before I purchased it; so, I’ve never had the pan off.
Can sludge really build up that much?
shew01 is offline   Reply With Quote
Old 05-24-2020, 09:39 AM   #6
Big hammer
Can sludge really build up that much? Only if you use non-detergent oil !
get a bigger hammer tap done
Old 05-24-2020, 02:29 PM   #7
1931 flamingo
1931 flamingo's Avatar
Over decades............and by not changing at 500-1000 miles. JMO
Paul in CT
Old 05-24-2020, 05:07 PM   #8
tinkirk
tinkirk's Avatar
If you just run it
It will find it's own level
Just keep an eye on it
It will be fine
tinkirk is offline   Reply With Quote
Old 05-25-2020, 08:26 AM   #9
30 Closed Cab PU
Originally Posted by shew01 View Post
I never thought about sludge potentially taking up space in the oil pan and altering the amount of oil required for a refill. My carÂ’s engine was rebuilt before I purchased it; so, IÂ’ve never had the pan off.
Like others above indicate, only if run for a very long time with non detergent oil.
After a 50 year nap, my A had inches of sludge built up in the bottom of the pan, had buildup in the Valve Galley, and had actually blocked the oil pump and oil pump screen. Luckily I caught it before it caused damage to the motor. It is the nastiest black/brown goo like molasses substance ever. Once on your hands or clothes is very difficult to clean off. Since multi-weight oil keeps contamination floating around in the oil, this is the reason some like to add the aftermarket oil filter kit.
Other contributors to sludge.
In the history of oil, manufacturers added Paraffin to motor oil to quiet valves and worn motors. Paraffin is wax. I believe this was in the 50s/60s
Motor coolant temps need to reach 160 degrees or more to allow the oil to reach temps that burn off condensation and other contaminants. Usually for more than 20 minutes. Some of us like to install a thermostat for this reason, and lubrication works better at higher temps, and the thermostat allows the temp to reach operating much quicker. Most wear happens at cold/lower motor temps.
Since your motor was rebuilt, your motor should be clean, especially since after rebuild it most likely has been using detergent oil.
30 Closed Cab PU is offline   Reply With Quote
Old 05-25-2020, 08:37 AM   #10
30 Closed Cab PU
deleted double post
Old 05-25-2020, 11:57 AM   #11
fred93
fred93's Avatar
New engine with zero miles--sludge is not an issue.
Old 05-25-2020, 12:08 PM   #12
fred93
fred93's Avatar
So how much oil goes in after draining out old oil?
Andrews says 4-1/2 quarts.
Old 05-26-2020, 06:39 AM   #13
Steve Plucker
You are going to have at least 1/2 quart (1 pint) left in the engine after changing the oil.
The engine capacity is 5 quarts. So on refilling, put in 4-1/2 quarts. That will get you to your 5 quart capacity.
I hate "guessing" at just how much is in the engine when I check it so I have marked my dipstick. For every quart added, there is a mark.
Some may not recommend this and that is OK...It works for me.
Just remember when you do this, that there is a 1/2 quart of oil in the engine already that must be accounted for.
Pluck
Old 05-26-2020, 06:57 AM   #14
ryanheacox
ryanheacox's Avatar
Is it an original or repro dipstick?
ryanheacox is offline   Reply With Quote
Old 05-26-2020, 08:53 AM   #15
Redbird
Redbird's Avatar
Half quart or so stays in the dipper pan when you drain your oil. Never overfill!
Redbird is offline   Reply With Quote
Old 05-27-2020, 12:41 PM   #16
burner31
burner31's Avatar
Oil capacity is five quarts, tray hold 1/2 quart, 4.5 quarts at oil change,
If you have no sludge in the pan.
At your next oil change run your pinky finger in the drain hole and "finger out" how much sludge is in there.
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
