Old 05-19-2020, 01:56 AM   #1
Lawrie
Lawrie's Avatar
Default pain in the but job on the 33 today
Any one who does a heap of miles in their old Fords and need to grease the U/J cavity will know what a job it is, getting the grease gun onto the nipple amongst all the brake rods, speedo cable and stuff, not to mention the split pins on the brake clevace pins, Ouch.
So today I made up a 3/16 id braided hose and little mount and now its just inside the l/h engine bay and as easy as to do.
I have been meaning to do this for ages .
Lawrie
Lawrie is offline   Reply With Quote
Old 05-19-2020, 10:20 AM   #2
RalphM
RalphM's Avatar
Default Re: pain in the but job on the 33 today
A lot of big trucks are set up that way, just open the hood and all your grease zircs are in one handy location. Only thing extra is the driveline. Which you seem to have taken care of. The only issue I’ve seen with it is to use the wrong kind of grease and it gets hard and then it won’t flow through the lines.
RalphM is offline   Reply With Quote
Old 05-19-2020, 02:46 PM   #3
19Fordy
19Fordy's Avatar
Great idea Lawrie. That's one reason I drilled and tapped clamshell and floorboard for an extended U-joint lube fitting on top of the clam shell. No more crawling under the car.
Old 05-19-2020, 06:58 PM   #4
Talkwrench
Talkwrench's Avatar
OK there are some joys of having a pickup, just lift the floor and you're there.
"Came too close to dying to stop living now!"
Talkwrench is offline   Reply With Quote
