#1 |
This started about a month ago....I crank it over with electric start and the motor is turning but suddenly it almost freezes with a hard "stop" but then continues to crank . This may happen once or several times before it starts.
I thought the battery may have been losing it's cranking amps as it was 6 years old, so I got a new dry cell 6 volt. Still doing it. I'm thinking I'll reset timing, but why would timing just fade away? Yes the spark is retarded on starting. Thoughts Thanks Jim |
#2 |
I would definitely check the timing. Maybe the screw holding the cam was not tight enough and the cam slipped.
#3 |
Your lever may be up,but that distributor is not retarded. Check that linkage and make sure the cam is not rotating a little.
#4 | |
![]() Quote:
www.whidbeymodelaclub.com |
#5 |
If the hard stop is near TDC, it's probably the timing rater than a battery/starter.
<Link> This is how we roll<Link> "I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob Outcasts rules of old cars #1 Fun is imperative, mainstream is overrated #2 If they think it is impossible, prove them wrong #3 If the science says it impossible you are not being creative enough. #4 No shame in recreating something you never had #5 If it were not for the law & physics you would be unstoppable |
#6 |
Just something else to try. Good luck |
#7 | |
![]() Quote:
#8 |
KATY: The battery has no liquid acid in it, can't spill. Jim's Battery sells them to look exactly like original battery, but many makes are out there. Snyder's sells this version:
OPTIMA BATTERY 6V A-10655-6 The Optima is a sealed battery so we are able to ship it within the U.S. by UPS or Federal Express. I my have used the wrong term, "SEALED" it may be Glass Mat :---BU-201a: Absorbent Glass Mat (AGM) Learn what differentiate AGM from other lead acid battery types AGM technology became popular in the early 1980s as a sealed lead acid battery for military aircraft, vehicles and UPS to reduce weight and improve reliability. The sulfuric acid is absorbed by a very fine fiberglass mat, making the battery spill-proof. This enables shipment without hazardous material restrictions. At any rate it can't leak. Last edited by jg61hawk; 05-20-2020 at 12:03 AM. |
#9 |
Did the original issue get resolved? Curious minds are wondering....
#10 |
jg61hawk, got the picture, thanks for the info, Ken
#11 |
Bill G,,,Not sure yet....Today I used the Nu Rex tool and set timing and "step 3" extrta retard" for easy starting. Problem continued. I then did the manual old way and set timing with test light and by hand... I THINK the problem is gone...just not trusting yet...I'll always post the solution...may have a new situation too. Was running good than developed a backfire like an hour later....CONDENSER??? I'll post,
#12 | |
![]() Quote:
Unrelated, you wouldn't happen to be a Studebaker owner are you ? |
#13 | |
![]() Quote:
Did the "backfire" sound like a shotgun out the exhaust, or was it more of a cough at the carb? |
#14 |
Patrick L...Yes 61 hawk.
#15 |
The hard stop was apparently related to timing. The backfire was loud shotgun, actually neighbors came over.... I think I resolved that too. Long story: When I got the new battery (Jim' Auto battery formally Antique Auto battery) the instructions were very clear don't let it charge over 8 volts. I ended up moving the brush on the generator all the way up to only get 7 volts. At any rate generator was not charging the battery and when I checked the battery had only 6.02 running. I assume the low voltage was breaking down the spark system, because I upped the charge and things got all better.
#16 |
Glad its fixed. I happen to like Studebakers even more than 'As'. I was born in a Studebaker parts room.
