Old 05-16-2020, 02:32 PM   #1
Superhart
Superhart's Avatar
Default Sliding Lock Rivet Nuts
I need to find the 10-32 rivet nut inserts on the inner door panel that the screws for the sliding lock assembly screw into. Would anyone have any ideas or suggestions? The modern 10-32 rivet nuts are too small in diameter to fit securely in the holes in the panel.
Superhart is offline   Reply With Quote
Old 05-16-2020, 02:40 PM   #2
Colorado Greg
Colorado Greg's Avatar
Default Re: Sliding Lock Rivet Nuts
Bert's has them https://modelastore.com/restoration-...nuts?limit=100
"Betsy doesn't leak oil - she just marks her spot"
Colorado Greg is offline   Reply With Quote
Old 05-17-2020, 08:13 AM   #3
Big hammer
Use washers, 2 ea, one under the head one on the back side?
get a bigger hammer tap done
