Old 05-12-2020, 09:51 PM   #1
dmaxweb
dmaxweb's Avatar
Default Door Latch Rods 30 Coupe
The end of the rods are worn and no longer fit snug in the recess (2 flat sides and 2 rounded sides) of the interior door handle. Because of this the handle will not stay tight. For the very small amount of material that needs to be added, welding and filing down seems extreme. I thought about applying a thin layer of Marine Tex epoxy to build it up and then sand down to fit. Another option is repro rods but they may be worse than the worn originals I have.
Any thoughts or suggestions?
dmaxweb is offline   Reply With Quote
