Old 04-29-2020, 06:45 AM   #1
lrjones
Default Hinge Pins
Are the original hinge pins on the door knurled at the top of the shaft? Tried driving one up from the bottom but no luck due to the fact that you can't get a good angle with the punch and hammer. Also tried a small air hammer. Broke the Snyders tool. If the pin is knurled it would be difficult to to drive the pin down from the top but would be able to get a better strike on the punch. Thanks for the advice
lrjones is offline   Reply With Quote
