Old 04-18-2020, 10:07 PM   #1
mach0415
mach0415's Avatar
Default Distributor Upper Contact Plate
I recently bought what appears to be a very original 1928 Canadian Tudor. As I have been going over things, I began to check ignition component clearances and noticed the points did not line up correctly. I purchased a new set and when I went to install them, I noted the new set do not align correctly, but there is also no adjustable block in order to align them. I attached pictures, because based upon other pictures, I am now thinking the upper contact plate is not original. It appears to have some sort of copper or bronze finish. The pencil is also pointing to a broken bake-o-lite insulator (it flaked apart as I was installing the points terminal stud) and now the plate will need replacing anyway. Any thoughts on whether or not this is an old aftermarket replacement plate?
Thanks in advance for any info...
Thanks,
Mark in SC
"We the unwilling, led by the unknowing, are doing the impossible for the ungrateful." -- By society, who is still arguing over who said it.
mach0415 is offline   Reply With Quote
Old 04-19-2020, 02:31 AM   #2
juke joint johnny
juke joint johnny's Avatar
Default Re: Distributor Upper Contact Plate
That's an original 28 plate .In fact my Briggs 29 Fordor has one .
The stamped style came out later
You might be able to swap the bac-o-lite from the later type
juke joint johnny is offline   Reply With Quote
Old 04-19-2020, 07:11 AM   #3
mach0415
mach0415's Avatar
Thanks for the response. I may just run a stamped version and seek to restore this one at a later time. It would appear that points have grown about 1/8 inch over the years too, so the contacts do not meet well. Perhaps in that time I may find some that do.
Thanks,
Mark in SC
Old 04-19-2020, 07:15 AM   #4
chrs1961815
chrs1961815's Avatar
I do believe the very early plates had different points so that might be your problem.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 04-19-2020, 07:31 AM   #5
30 Closed Cab PU
This may work, Brattons has a modified points block.
Not sure the mounting on this will match your plate.
https://www.brattons.com/machined-di...int-block.html
30 Closed Cab PU is offline   Reply With Quote
Old 04-19-2020, 08:03 AM   #6
Sunnybrook Farm
Sunnybrook Farm's Avatar
I have never seen any other than in a photo but the early points would just slip in with out unscrewing the nut on the bottom of the plate. They changed it because people could steal them or the car, can't remember exactly. So you have to lose the timing to change the points after they modified the design. I have a couple of the 28 design, the layout of where things are is a little different but it works fine, I think I put a new fiber plate on one but made it new so it would line up. Could be Ford contracted with several vendors to make the things.
Sunnybrook Farm is offline   Reply With Quote
Old 04-19-2020, 09:06 AM   #7
mach0415
mach0415's Avatar
Is there a resource anyone is aware of to acquire the older style points? Thanks
Thanks,
Mark in SC
Old 04-19-2020, 09:24 AM   #8
ryanheacox
ryanheacox's Avatar
I bought a NORS P&D set on eBay a couple years ago. Quality is great and after adjusting them 100 miles in I haven’t had to touch them.
https://www.ebay.com/itm/153899264321 Here is a set that looks pretty good. Condenser is likely junk though.
ryanheacox is offline   Reply With Quote
Old 04-19-2020, 11:58 AM   #9
Ruth
This machined point block from Bratton's is very nice, my points line up perfectly. But the point block on the early plate like the Op's is not removable.
Ruth
Old 04-19-2020, 12:02 PM   #10
rocket1
I bought aftermarket points from Napa they don't line up,I compared arm length to Ford script points,the Eschelin arm is longer.
rocket1 is offline   Reply With Quote
Old 04-19-2020, 12:22 PM   #11
Bob C
I think these are the very early points.
Bob
Bob C is online now   Reply With Quote
Old 04-19-2020, 09:19 PM   #12
mach0415
mach0415's Avatar
Yes this is what I found to be true too.
Thanks,
Mark in SC
