Old 04-19-2020, 07:31 AM   #1
30 Closed Cab PU
Default Re: Distributor Upper Contact Plate
This may work, Brattons has a modified points block.
Not sure the mounting on this will match your plate.
https://www.brattons.com/machined-di...int-block.html
Old 04-19-2020, 11:58 AM   #2
Ruth
This machined point block from Bratton's is very nice, my points line up perfectly. But the point block on the early plate like the Op's is not removable.
Ruth
