Old 02-27-2020, 12:43 AM   #1
Phil Gillespie
Phil Gillespie's Avatar
Default 39 Ford Rear hub fitment
The rear hub nut, etc for securing the drum at 200ft lb also comes with a fibre washer the sits in the spigot before fitting washer and nut.
Is it really necessary to use this fibre washer? What does it actually do?
Thanks
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 02-27-2020, 12:55 AM   #2
Brian
Brian's Avatar
Default Re: 39 Ford Rear hub fitment
It's a seal; any oil migrating down the keyway for example, can go no further.
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 02-27-2020, 12:58 AM   #3
ford38v8
ford38v8's Avatar
There's no real torque on that fiber grease seal. It sits tucked into a pocket that allows it to be compressed just enough to provide the seal.
Alan
Old 02-27-2020, 01:03 AM   #4
Phil Gillespie
Ok thanks for that will make sure they are fitted. Good to get correct info as always.
If you dont ask the knowledge base cant be expanded.
Phil NZ
Old 02-27-2020, 01:04 AM   #5
Tinker
Tinker's Avatar
You can cut one as simple from stock stuff also. Felt is not hard to find. Agreed it's not that hard line. thin felt. Wouldn't worry about it. These cars need attention. You'll be checking it every spring anyway.
Old 02-27-2020, 08:07 AM   #6
JM 35 Sedan
JM 35 Sedan's Avatar
The fiber washer/gasket made by Best and supplied in their banjo rear gasket set, does an excellent job of sealing that area of the rear hub, behind the washer, when axel nut is torqued in place. However, it seems to be a one time deal. Once you remove that drum again, it's best to use a new fiber washer if/when putting that drum back on. They are inexpensive, and can be purchased separately.
John
Old 02-27-2020, 09:22 AM   #7
19Fordy
19Fordy's Avatar
You can make one from an old leather belt.
Old 02-28-2020, 01:28 PM   #8
fordlovr
fordlovr's Avatar
Hi Phil, I just got a new pair from Ajays. Fit nice! Bryn
fordlovr is offline   Reply With Quote
