Old 02-25-2020, 11:35 AM   #1
Andy
Default Strange brake drums
I had a rear end a few years ago that had the strangest rear drums. It was a 35 or 36. I could not tell witch. The drums had both wheel stud pattern studs. They were swedged in. The drums were open design and I could see the internals. You could mount either 5.5 wheels or wide five ones.
Maybe aftermarket?
Andy is offline   Reply With Quote
Old 02-25-2020, 12:44 PM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: Strange brake drums
Where did your avatar go, Andy? Maybe you need a new one with a little different flair, for instance: DD
Click Links Below __
T5 W/TORQUE TUBE
Old 02-25-2020, 01:35 PM   #3
Brian
Brian's Avatar
There are 36 rear drums that are two piece. The hub bolts onto the drum using 5 bolts on [probably] 5 1/2" bolt pattern. They are however the large bolt pattern drums as used 36-39
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 02-25-2020, 01:40 PM   #4
CA Victoria
CA Victoria's Avatar
Grumman S-2?
Tim
Downtown, Ca
CA Victoria is offline   Reply With Quote
Old 02-25-2020, 02:30 PM   #5
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by CA Victoria View Post
Grumman S-2?
Douglas B-26 with a prototype Garrett TPE 331 engine glued onto the nose for flight testing. DD
T5 W/TORQUE TUBE
Old 02-25-2020, 06:08 PM   #6
cas3
i have some two piece wide 5's, but never seen any with both patterns. interesting idea
Old 02-25-2020, 06:49 PM   #7
JM 35 Sedan
JM 35 Sedan's Avatar
Maybe aftermarket?
Andy, I have seen those unusual drum/hub combinations you are referring to, and may even have a couple of them in my stash of stuff. It almost looks like 'Ol Henry, or his part supplier, salvaged some '35 hubs, and made them into drum/hub assemblies that could be used in '36 as wide fives.
John
Old 02-25-2020, 06:54 PM   #8
Mart
Mart's Avatar
I might be wrong but I seem to remember reading that type were early 1936 model year.
Mart.
Old 02-25-2020, 07:00 PM   #9
Mart
Mart's Avatar
I found this one pic on the hamb. Might have been rear only?? Fronts also have windows but are one piece (or at least one bolt pattern).
Edit: this is the thread: https://www.jalopyjournal.com/forum/...oject.1065912/
Old 02-26-2020, 09:52 AM   #10
uncle buck
uncle buck's Avatar
I need to get some of that glue!
uncle buck is offline   Reply With Quote
Old 02-26-2020, 04:58 PM   #11
JM 35 Sedan
The rear drums are the only ones I've seen made like this, although I do have both front and rear open type "Rockey Mountain" '35 drums.
John
