Old 02-17-2020, 11:25 PM   #1
lonewolf
Default 1935 1936 ford pickup bumpers
Will 35 Ford pickup front and rear bumpers bolt on to a 36 ford pickup using 36 ford pickup brackets. Someone put 36 car bumpers on my pickup and I would like to change them to the straight pickup style bumpers. I found a good deal on some 35 pickup bare bumpers. What's the difference between the 35&36 pickup bumpers. Thanks
lonewolf is offline   Reply With Quote
Old 02-18-2020, 12:22 AM   #2
mercman from oz
mercman from oz's Avatar
Default Re: 1935 1936 ford pickup bumpers
The difference between the 1935 and 1936 Ford Pickup Bumpers are the ends.
Just like the Bumpers on the similar model passenger cars, the 35 Bumper ends are nearly vertical, while the ends of the 1936 Bumpers are angled at nearly 45 degrees. On the Pickups, there is no dip in the centre like on the passengers cars. Hope that this helps.
mercman from oz is online now   Reply With Quote
Old 02-18-2020, 12:33 AM   #3
deuce lover
deuce lover's Avatar
Mercman has it right with those pics.Also The outer brackets are different from '35 to '36.'36 dip down at the ends.
deuce lover is offline   Reply With Quote
Old 02-18-2020, 04:34 AM   #4
JM 35 Sedan
JM 35 Sedan's Avatar
Also, the front bumper brackets on '35 pickups vs. '35 passenger cars are the same, and ditto on the '36 pickups vs. '36 passenger cars. The front inner brackets are the same for both years, on both pickups and pass cars.
I've seen folks force fit '36 bumpers on '35 pu's and pass cars while using their stock/original bumper brackets, and vice versa with '35 bumpers on '36 vehicles. It can be done, either way, but something has to give (bend) as the bumper bolts are fully tightened.
John
