Old 01-31-2011, 05:14 PM   #1
Tom's36coupe
Tom's36coupe's Avatar
Default Removing white letters on plug wires
I have a new set of Taylor 8mm spark plug wires and would like to remove the lettering that is on them, what works good to get it off without hurting the surface? Lacquer thinner work?
Tom's36coupe is offline   Reply With Quote
Old 01-31-2011, 05:28 PM   #2
Coupe35
Default Re: Removing white letters on plug wires
I have used lacquer thinner on rubbber fuel line to removed the lettering and it worked fine. Should work on plug wires too.
Coupe35 is offline   Reply With Quote
Old 01-31-2011, 06:13 PM   #3
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
I use brake clean sprayed on a rag......
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 01-31-2011, 07:52 PM   #4
alanwoodieman
goof-off sold in the paint department of about every K-mart, Wall-mart, etc
alanwoodieman is offline   Reply With Quote
Old 01-31-2011, 08:57 PM   #5
paul2748
paul2748's Avatar
I think I used lacquer thinner on mine. Brake clean should work.
