Old 10-21-2019, 08:58 AM   #1
jwilliams81
jwilliams81's Avatar
Default Rear Motor Mount rubber replacement video for you
Hey everyone,
While I have my engine out I decided it was time to replace the original and rock hard rear engine mount rubber. I made a little video of the process. It was very straight forward and very easy with the engine out of the way
Here is the link:
https://www.youtube.com/watch?v=ucAbLIm1j64
1931 Murray Town Sedan. Black body with Apple Green pin stripe.
1923 Model T Touring with electric start. Low radiator
Cincinnati, Ohio
jwilliams81 is offline   Reply With Quote
Old 10-23-2019, 09:12 PM   #2
Curtis in MA
Default Re: Rear Motor Mount rubber replacement video for you
Can you replace the rubber pads without removing the engine?
Curtis in MA is offline   Reply With Quote
Old 10-24-2019, 12:10 PM   #3
jwilliams81
Yes of course.
You can support the engine with a jack under the pan most likely. then just unbolt the mounts from the flywheel housing.
Try and remove the mount to frame bolts, but in my case all 6 snapped from rust.
Cincinnati, Ohio
Old 10-24-2019, 12:19 PM   #4
Curtis in MA
I'll make that a winter project.
Thanks.
