Old 10-08-2019, 05:25 PM   #1
Topher5150
Default panhard bushings
I bought the panhard bushings for my 47 coupe from macs (part number 64-15742) they are a bit wider than the bracket. Is this a part that gets smooshed into place I tried a few different ways but it seems to come out the same. Also what size bolt holds the bar to the bracket
Topher5150 is offline   Reply With Quote
Old 10-09-2019, 02:54 AM   #2
Blix
Default Re: panhard bushings
I also bought those bushings from mac's and I had to cut them down to be able to fit them. I am thinking of making my own (casting urethane in a plaster mold. Also the bushings from mac's are to soft!
Blix is offline   Reply With Quote
Old 10-09-2019, 09:36 AM   #3
TJ
TJ's Avatar
Check with energy suspension. They have all sorts of urethane bushings and you may find some that will fit. I recall that years ago I used some urethane bushings from a rod shop that fit a four bar front end that worked on the 42-48 sway bar.
Old 10-10-2019, 02:27 PM   #4
Topher5150
seems simple enough
Old 10-10-2019, 03:18 PM   #5
Blix
Thanks, i looked at my 34 for roadster project with four bar front suspension and you are right those bushings seems to fit on the panhard rod on my 46!
Old 10-10-2019, 05:22 PM   #6
TJ
TJ's Avatar
Glad I could help.
Old 10-10-2019, 06:07 PM   #7
fortyfords
fortyfords's Avatar
Another thought, change over to rod ends.
fortyfords is offline   Reply With Quote
