Old 10-04-2019, 09:02 AM   #1
Stumann
Default Interior piece
I'm working on all the wood for the interior on my 30 Model A. I'm not sure what to do with this piece I have pictured. I don't even know what to call it. It looks like it used to have maybe leather in it or something similar to staple to, but I'm not sure. What do you guys usually do with this piece? Is it available new? Thanks, Stu
Stumann is offline   Reply With Quote
Old 10-04-2019, 09:22 AM   #2
burner31
burner31's Avatar
Default Re: Interior piece
Belt and/or tack rail
Used to fasten your interior material
Yes you can buy it, but it's not cheap...why I don't know
Question: Has your top been chopped/lowered? Those welding scars look massive
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 10-04-2019, 09:33 AM   #3
burner31
burner31's Avatar
Tack strips are cut from kiln dried hardwood
But there must be a substitute out there that can be used
I'll be in need of some of tack railing in the future but don't like the idea of forking over the mountain of cash for these pieces
Keith
Shawnee OK
'31 SW 160-B
Old 10-04-2019, 10:05 AM   #4
Chuck Dempsey
Chuck Dempsey's Avatar
Check out this video from Classtique, around the 5:20 mark, they mention that strip.... https://www.youtube.com/watch?v=b33dNXD2lBQ
Chuck Dempsey is offline   Reply With Quote
Old 10-04-2019, 10:21 AM   #5
redmodelt
redmodelt's Avatar
Snyders sells the kit to replace the filler that slides into the metal channel. The original was pressed card stock.
https://www.snydersantiqueauto.com/P...earchByKeyword
Old 10-04-2019, 10:37 AM   #6
vern hodgson
Attachment 408552
Actually sounds as if you want the piece of wood that fits up in the corner where the slots are. That what you put your roof tacks into, yeah, they are pricey.
vern hodgson is offline   Reply With Quote
Old 10-04-2019, 11:02 AM   #7
Stumann
Thanks, Chuck Dempsey. That video was very helpful.
