Old 08-26-2019, 05:05 PM   #1
adileo
adileo's Avatar
Default Sanity check 39 rear brakes
Hi guys
In the 5-6 years since the purchase of my 39 coupe, I’ve put about 12k miles on it. I’m thinking I would like to adjust the rear brakes (front are disc).
Am I correct, this adjustment is all done with the upper bolt shown in pic?
Also am I correct that (with emergency brake off) I would tighten one side till I can’t turn wheel then back off till I can turn - then repeat procedure on the other shoe (same wheel)?
File Type: jpg 0DF8B358-B6D3-437D-8D40-AF36469CC4D8.jpg (53.3 KB, 19 views)
Thanks
Andy
1952 F1
adileo is offline   Reply With Quote
Old 08-26-2019, 07:02 PM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: Sanity check 39 rear brakes
Andy...Click the link below for a comprehensive "how to" on adjusting '39 thru '41 brakes the correct way. DD
http://www.btc-bci.com/~billben/brakeadj
Click Links Below __
T5 W/TORQUE TUBE
Old 08-26-2019, 07:20 PM   #3
petehoovie
petehoovie's Avatar
VIDEO - How To Adjust Early Ford Hydraulic Brakes with Wide 5 Drums > https://www.youtube.com/watch?v=Jn_XofkYjLc
Old 08-26-2019, 07:37 PM   #4
adileo
adileo's Avatar
Perfect thanks so much!!!
Thanks
Andy
1952 F1
Old 08-26-2019, 07:21 PM   #5
adileo
adileo's Avatar
DD thanks hope all is well.
this is the part I (red) believe is what I was referring to;
File Type: jpg 0F02DDCB-6447-48D9-8B93-CAA8952D6B1E.jpg (63.6 KB, 65 views)
Thanks
Andy
1952 F1
Old 08-28-2019, 06:08 PM   #6
adileo
adileo's Avatar
Hi guys
Ok adjusted brakes with assist from video. Went well...
Follow up question. While up on lift and examining lower brake pins I noticed that the front shoe driver side pin/dot (see attached) was facing in. In reading directions, this position for starting adjustment process. Is this an indication shoe is not centered properly?
File Type: jpg 6ED33FD7-6892-4C03-85D4-037E5FAA47CD.jpg (100.5 KB, 27 views)
Thanks
Andy
1952 F1
Old 08-29-2019, 11:01 AM   #7
alchemy
alchemy's Avatar
It might mean that shoe is very thick and is fully adjusted at that point. Or, it could be wrong, but if it stops nicely I'd leave it as-is. Check them again in a year.
alchemy is offline   Reply With Quote
Old 08-29-2019, 03:25 PM   #8
supereal
supereal's Avatar
Brakes should not be adjusted with the shoe mounting bolts. Use the eccentric adjusters lower on the backing plate, the ones with the 11/16 heads. As you have a combination of disc and shoe brakes, I assume you have a proportioning valve between the front and rear brakes, and hopefully a dual master cylinder for safety.
supereal is offline   Reply With Quote
Old 08-29-2019, 05:38 PM   #9
adileo
adileo's Avatar
I do thanks
Thanks
Andy
1952 F1
