Old 08-07-2019, 06:13 PM   #1
DannL
DannL's Avatar
Default Pulling the instrument cluster . . .
I'm getting ready to pull the instrument cluster from the dash but I noticed there was fluid behind the gas gauge. I was told I need to remove the whole cluster in order to reconnect the speedometer cable.What should I expect when the cluster comes out? Thanks in advance.
DannL is offline   Reply With Quote
Old 08-07-2019, 06:24 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Pulling the instrument cluster . . .
The gas you see will stay put until the gauge is needed to be removed, the cluster is not attached to the gauge.,
Old 08-07-2019, 06:27 PM   #3
Synchro909
Synchro909's Avatar
The fluid behind the glass is what you guys call gas. When you remove the dash panel, that stays behind so it will not be an issue. Have a close look at the dash panel around the gauge and you'll see where it is not part of the fuel gauge.
I sometimes wonder what happened to the people who asked me for directions.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Synchro909 is online now   Reply With Quote
Old 08-07-2019, 06:33 PM   #4
1955cj5
1955cj5's Avatar
Disconnect the battery first!
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 08-08-2019, 07:25 AM   #5
chap52
chap52's Avatar
While you have the cluster out check the condition of ignition switch and ammeter wires. Put some graphite lube in the speedo cable and button it all back up. Enjoy the adventure... Chap
chap52 is offline   Reply With Quote
Old 08-08-2019, 08:16 AM   #6
Russ/40
Russ/40's Avatar
Since finishing my truck, THAT is the task I hate the most.
Russ/40 is offline   Reply With Quote
