Old 07-31-2019, 10:40 PM   #1
Steve in Denver
Steve in Denver's Avatar
Default '36 5W quarter window water seal
On my '36 5 window, there is rust just above the running board, right below the quarter window. In talking with someone else, he said it was a common problem with the window leaking.
Sooo… what is the best sealant to put around those windows? I don't want to go to the local glass shop because the stuff they use is heated and designed to never come off unless it is cut off. Do I want the 3M sealant or a Home Depot clear silicone? Or is there something better.
Steve in Denver is offline   Reply With Quote
Old 07-31-2019, 10:45 PM   #2
Tinker
Tinker's Avatar
Default Re: '36 5W quarter window water seal
Pull the window and put in a new gasket?
Old 07-31-2019, 11:09 PM   #3
Steve in Denver
Thanks, does it have a natural seal to it?
Old 07-31-2019, 11:10 PM   #4
Tinker
Tinker's Avatar
Well it worked before. Weather stripping deteriorates over time.
The rear window water drain also goes to that spot. So maybe a bit there.
Old 08-01-2019, 09:02 AM   #5
Willit Stop
Willit Stop's Avatar
I used 3M glass bedding compound. It comes in a caulking tube, looks like tar and will not dry completely. Kind of messy but it works.
Willit Stop is offline   Reply With Quote
Old 08-01-2019, 09:15 AM   #6
Steve in Denver
Thanks, that is what I was looking for. With new seals, that should keep it from happening again. I will extend the rear window drain through the floor board as well. I think there is a hole there already.
