Old 06-16-2019, 10:49 AM   #1
Nico73
Nico73's Avatar
Default Turning coupling shaft-housing
Good Evening Everybody,
just finished to install The 2 New u-joints on my 1934 1.5 Ton Truck ( Long wheel base) and have The following Problem. When i turn a rear wheel, the Front coupling shaft housing starts to turn too.
Seems like it has contact to The rear U-joint.
Instead of using a gasket, i take Silikon-sealer for The rear u-joint Cover Flange & torque Tube Ball cap. All Retainer Capsrews are in place.
Any advices/ideas now to aligne The coupling shaft-housing in a good way?
Thank's Nico
Nico73 is offline   Reply With Quote
