Old 05-23-2019, 12:22 PM   #1
tommyleea
Default 53 Ranch Wagon wheel studs
So, I found out that the front wheel studs are swedged. Are the rear the same or are they pressed in? Flathead engine.
Reason I am asking, is because when I purchased the Ranch Wagon there were no rear drums on it. I am replacing the wheel bearings now, and looking at the wheel studs, they appear to have the same bulge at the base as the front studs have. So, if I buy brake drums for the rear, will they just slide on without interference from the studs?
tommyleea is offline   Reply With Quote
