Old 05-13-2019, 05:17 PM   #1
Fullfendered
Fullfendered's Avatar
Default Guides resusable?
Are these guides reusable with the gouge on end? Was going to have Gofast put bronze liner in them. Thank you.
Fullfendered is offline   Reply With Quote
Old 05-13-2019, 06:10 PM   #2
GOSFAST
GOSFAST's Avatar
Default Re: Guides resusable?
Hi Doug, send as many as will fit in the box (you have a PM), we'll get a good set I'm sure? (See the photo below)
If you are supplying your own valves would like at least one to "fit" to the guides, if we are supplying new valves we won't need any from you!
Thanks, Gary in N.Y.
P.S. Difficult to really tell how "bad" they are from the photos, all may be OK to use. They look usable to me but obviously we can tell better when we have them here!
GOSFAST is offline   Reply With Quote
Old 05-13-2019, 07:02 PM   #3
Tim Ayers
Curious as to what did that to the guide tops...
Old 05-13-2019, 07:06 PM   #4
Talkwrench
Talkwrench's Avatar
Just get Gary to do you a whole set.. I vouch for them!
"Came too close to dying to stop living now!"
Talkwrench is offline   Reply With Quote
Old 05-13-2019, 07:28 PM   #5
51 MERC-CT
51 MERC-CT's Avatar
Sounds simple to me, it's from whatever tool was used to sledge hammer them out.
Old 05-13-2019, 07:45 PM   #6
Tim Ayers
Yeah, maybe. They look cut. Maybe a chisel?
Old 05-13-2019, 08:05 PM   #7
Pete
If they are not TIGHT in the block, no liners or oversize stems will help.
They should fit into the block metal to metal. The liners should be installed AFTER the guides are in the block.
Old 05-14-2019, 06:15 AM   #8
JWL
Those nicks and chips in the top do not disqualify the guides from use. If the burrs are removed and the valves have reasonable clearance at the stems they will be fine.
JWL is offline   Reply With Quote
Old 05-14-2019, 08:25 AM   #9
GOSFAST
GOSFAST's Avatar
Just to add, when we do the liners we spotface most of the tops and the bottoms of the guides. (See photo below, this set had minimal stock removal from the bottoms, they were all in excellent condition)
There could be as much as .040" removed from those damaged areas. Has no effect on the integrity of the guides whatsoever!
P.S. When we finish machining for the liners the O/L of the guides are very close to each other. May be a slight variation only.
File Type: jpg Flathead Valve Guides-Bottoms Spotfaced.jpg (78.6 KB, 54 views)
