Old 05-11-2019, 09:08 PM   #1
31Abone
31Abone's Avatar
Default 21 stud motor oil leak rear of pan area
1934 21 stud motor leaking oil out of rear pan small hole under flywheel about a half cup when hot after a run ..do I need to pull the motor to fix it ?? oil getting on clutch and chattering ..
31Abone is offline   Reply With Quote
Old 05-11-2019, 10:11 PM   #2
JSeery
JSeery's Avatar
Default Re: 21 stud motor oil leak rear of pan area
That's not really part of the oil pan (as in the part that contains oil). It is the lower flywheel/clutch cover. The hole is to allow any oil that gets past the rear main seal a place to escape. And the rear seals tend to leak. The oil is leaking down between the rear of the block and the flywheel and should not get on the clutch surface. One reason for the rear seal to leak (which is basically just a slinger) is over filling the oil or something else that is increasing the oil escape through the slinger. There should be a cotter pin in the hole that jiggles around to keep it open.
Old 05-12-2019, 12:56 AM   #3
ford38v8
ford38v8's Avatar
Too much oil in the crankcase, or parking on an uphill slope will cause oil to run over the slinger into the clutch cover, but the clutch chatter would be caused by loose or worn out motor mounts.
Alan
Old 05-12-2019, 07:55 AM   #4
Adam/Mill Valley CA
Adam/Mill Valley CA's Avatar
I had the same issue with my '36, which has a poured-bearing 21 stud motor. There is a cork gasket strip separating the main oil pan from that rear clutch/flywheel chamber, it had basically corroded to the point where it was no longer keeping oil in the pan. Pulled the oil pan, replaced the seal and all was well.
Adam
1936 pickup, stock, black
1965 Mustang coupe 289/4bbl, black/red
1971 Alfa Romeo GTV 1750 coupe, dark red/tan
1970 911E 2.2 litre dark blue/black
1968 BMW R50/2 US, black (m'cycle)
1967 Triumph TR6R , sea foam/cream (m'cycle)
2022 Royal Enfield Interceptor 650 red (m'cycle)
1974 Honda CB750 red (m'cycle)
2000 Kawasaki W650 blue/silver (m'cycle)
Adam/Mill Valley CA is offline   Reply With Quote
Old 05-12-2019, 12:42 PM   #5
31Abone
31Abone's Avatar
Good reply's.. I'm familiar with Model A and B oil slingers and the return pipe, does 21 stud have a return pipe as well ? guess I need to drain oil and see how much oil is in pan ,reinstall and add 5 quarts and calibrate dip stick..plugs look good "not perfect" and no exhaust smoke..I started motor on the hoist while running and could see no oil leaks ..but at speed on the road and then stopping oil comes out of clutch cover drain hole at a rapid rate.....fun never ends with old cars.
Old 05-12-2019, 02:16 PM   #6
JSeery
JSeery's Avatar
Originally Posted by 31Abone View Post
Good reply's.. I'm familiar with Model A and B oil slingers and the return pipe, does 21 stud have a return pipe as well?
Some do and some don't, almost need to check to be sure.
Old 05-12-2019, 03:48 PM   #7
Ken/Alabama
Ken/Alabama's Avatar
A worn rear main bearing with too much clearance will cause it also.
Ken/Alabama is offline   Reply With Quote
Old 03-14-2021, 02:34 PM   #8
mumpsimus
mumpsimus's Avatar
Adam
Adam, I’m going to investigate if my motor has the same failed gasket. Where did you buy your replacement gasket?
mumpsimus is offline   Reply With Quote
Old 03-14-2021, 03:22 PM   #9
Jack E/NJ
Jack E/NJ's Avatar
As I recall on my 21-studder, there seemed to be a leaking deteriorated. broken & misaligned cork/rubber composite pan/slinger gasket. It's shown in red highlight on the VanPelt image below. A replacement wasn't found or included in my gasket set nor did I find a part number. So a replacement was fashioned from an old neoprene spin-on oil filter ring gasket held in place with contact cement. Jack E/NJ
Jack E/NJ is offline   Reply With Quote
Old 03-14-2021, 05:36 PM   #10
mumpsimus
mumpsimus's Avatar
Thanks Jack! That image helped me to understand. I can make up a similar gasket.
Old 03-14-2021, 05:41 PM   #11
mumpsimus
mumpsimus's Avatar
I’ll see if I can replace the rear main bearing while I’m down there. And add a drain tube if there isn’t one.
Old 03-14-2021, 06:02 PM   #12
Lawrie
Lawrie's Avatar
You won't be able to replace the rear main bearing, as its a poured one.
Lawrie
Lawrie is offline   Reply With Quote
Old 03-15-2021, 05:43 AM   #13
Mac VP
Mac VP's Avatar
Don’t forget while you’re working in this area to replace the oil pump idler cover gasket on the backside of the block. It’s not unusual for the five bolts to be a little loose too. It would leak plenty of oil if the cover was not tightly sealed to the block.
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.vanpeltsales.com
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 03-15-2021, 08:01 AM   #14
deuce lover
deuce lover's Avatar
Ken/Alabama has it right.Happened to a buddy with a poured main bearing 21 stud engine.He pulled the pan and pieces of the Babbit showed up in the pan.Time to look for a '36 LB insert main bearing block.
deuce lover is offline   Reply With Quote
Old 03-16-2021, 02:41 AM   #15
bobH
Talking Re: 21 stud motor oil leak rear of pan area
I believe I remember this.... But, my recollection is that there was also a 'benefit'... The substantial leak caused an oil film to cover EVERYTHING under the car (34 sedan), from the pan rearward. It was a great preservative, resulting in nothing got rusty. Of course, the 'downside' was something like a couple quarts of oil every 50/100 miles.
bobH is offline   Reply With Quote
Old 03-16-2021, 02:48 AM   #16
deuce lover
That was Apple Valley.Good memory ,Bob.
Old 03-16-2021, 11:03 PM   #17
mumpsimus
mumpsimus's Avatar
Thanks for the tip! I’ll look into that too.
Old 03-17-2021, 08:00 PM   #18
FlatheadTed
FlatheadTed's Avatar
I have had this problem to ,to solve it you can Glue two pieces of 3mm neoprene rubber mix together with contact adhesive .The tube needs to be fitted as well , that worked for me ..
http://www.flatheadted.com
Flathead Ted brake Floaters ,
