Old 05-11-2019, 06:28 AM   #1
burnette
Default 12 volt head lights
i was afraid of installing halogen headlights in my 42 truck. will they draw to much current. i was looking for regular 12 volt headlamps ,but can,t seem to find any ! i don,t care for newer looking led ones, what do you guys use.
burnette is offline   Reply With Quote
Old 05-11-2019, 07:04 AM   #2
chap52
chap52's Avatar
Default Re: 12 volt head lights
Are you dealing with "sealed beam" or old style bulbs? Chap
chap52 is offline   Reply With Quote
Old 05-11-2019, 07:09 AM   #3
burnette
seal beams 7 inch round. all the ones i find are halogen. i switched to 12 volt .
Old 05-11-2019, 07:15 AM   #4
Kurt in NJ
Kurt in NJ's Avatar
I have halogen in the model A with the stock 6 volt generator, 35 watt, no problems with keeping battery charged,
How many amps will your modified system make ---has the output been tested on the vehicle?
With the stock 6V system on a 42 I would be using 50 -60 watt halogens, it has over twice the charging capabilitys of the model A, stock should be 32 amps, though there are higher output generators as options
Old 05-11-2019, 07:24 AM   #5
joe 1950
joe 1950's Avatar
I ran halogens on a 1950 willy’s that i switched to 12 volts never had any problems with stock charging system they worked great
joe 1950 is offline   Reply With Quote
Old 05-11-2019, 07:28 AM   #6
JSeery
JSeery's Avatar
I just did a quick search and find lots of 6014 bulbs for sell. I'm I missing something here?
Old 05-11-2019, 07:28 AM   #7
burnette
i was told by a Buddy who installed 2 halogen seal beams on his 56 Chevrolet. that his lights would shut down by them self,like if they were over loading his wiring. he removed them and put back the old ones,everything went back to normal. i got new wiring bought from joe,s. and upgraded to a 12volt alternator. i will not be driving much at night if any .
Old 05-11-2019, 07:33 AM   #8
burnette
thanks i was only finding halogen ones napa or car quest could not find any non halogens sealbeams.
Old 05-11-2019, 07:35 AM   #9
JSeery
JSeery's Avatar
The ones I am seeing are not listed as halogen. Speedway is one source https://www.speedwaymotors.com/12-Vo...ulb,35745.html
Better link
Old 05-11-2019, 07:44 AM   #10
burnette
i never bought from eBay ,theres a first for everthing !
thanks again brian.
Old 05-11-2019, 08:59 AM   #11
joe 1950
joe 1950's Avatar
your friend who had the chevy probably had a bad headlight switch and the breaker probably opened up
Old 05-11-2019, 09:19 AM   #12
JSeery
JSeery's Avatar
thanks again brian.
I added a direct Speedway link. https://www.speedwaymotors.com/12-Vo...ulb,35745.html
Old 05-11-2019, 09:21 AM   #13
TJ
TJ's Avatar
If you are concerned you can always install a relay. Relays are cheap and easy to install.
Old 05-11-2019, 01:21 PM   #14
drolston
drolston's Avatar
12 volt non-halogen sealed beams plug right in and work pretty well, if they are properly aimed.
Old 05-12-2019, 07:14 PM   #15
Talkwrench
Talkwrench's Avatar
You can just buy APF halogen globes, pop straight in. I rewired mine with relay's [12v].
"Came too close to dying to stop living now!"
Talkwrench is offline   Reply With Quote
Old 05-12-2019, 09:19 PM   #16
Fordestes
I use a headlight relay from a 70's ford LTD /Thunderbird , its worked ok for the last 30 years, like stated above, the best way to go with the original headlight switch .
Fordestes is offline   Reply With Quote
Old 05-12-2019, 09:53 PM   #17
meric42
meric42's Avatar
I have fitted high power 6 Volt Halogen Semi-sealed headlights to my '41 Coupe and so have fitted a 6 volt, period correct relay to the headlight circuit. I now have headlights operating on 6 volts that are comparable to most modern headlights, and considerably better than standard 12 volt sealed beams.
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP
Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand
https://www.fordbarn.com/forum/album.php?albumid=580
meric42 is offline   Reply With Quote
