Old 04-20-2019, 12:27 AM   #1
Mtn Wudy
Mtn Wudy's Avatar
Default Flexible Fuel Line...
Who sells the best flexible fuel line ...?? I had trouble with the one I got ...
The trouble may have been the fitting that came with it ...The first three threads stripped right off ....I was switching back to an original pump from the electric with reg. Rubber hose....Thanks ahead of time ...I got this one from C&G,,it’s not their fault ,,,it wasn’t made by them ...Maybe just a fluke....
Whether you think that you can,or that you can't,you are usually right....H.Ford
Mtn Wudy is offline   Reply With Quote
Old 04-20-2019, 07:38 AM   #2
51woodie
51woodie's Avatar
Default Re: Flexible Fuel Line...
I purchased my flex fuel line from Denis Carpenter for my '46 Coupe. The part number is 18-9288-A for $9.95, and is shown in the catalogue to fit 33-48 pickups and cars. Also, DC also sells the clip that holds the steel line to the firewall, under P/N 18-9296, if you need one. Mine was left off when the previous owner installed a pressure regulator at the firewall.
51woodie is offline   Reply With Quote
Old 04-20-2019, 11:37 AM   #3
supereal
supereal's Avatar
If the threads strip, it is likely the hose was cross threaded, or that the threads were damaged on the line or the carb. Those fine threads, particularly if brass, are easy to cross thread if you didn't turn them in by hand before using the wrench.
supereal is offline   Reply With Quote
Old 04-20-2019, 01:48 PM   #4
Ken/Alabama
Ken/Alabama's Avatar
The best ones Ive found are from Robert Shewman. made from modern material thats not affected by todays fuel . His email is [email protected]
Ken/Alabama is offline   Reply With Quote
Old 04-20-2019, 07:31 PM   #5
JM 35 Sedan
JM 35 Sedan's Avatar
That's who I would suggest as well. He offers them with and without a check valve. I've had one on my avatar 35 Fordor for the last 8 years.
John
Old 04-20-2019, 09:07 PM   #6
39portlander
39portlander's Avatar
Get the FH-2V with the in-line check, this thread reminds me to order a spare for my parts stash.
39portlander is offline   Reply With Quote
Old 04-20-2019, 09:22 PM   #7
Mtn Wudy
Mtn Wudy's Avatar
Thanks guys.....
Sent him an email before I saw the post with the phone number .....
I got the new Drake fuel pump on and used that hose till I get the new one ...
