Old 02-07-2019, 05:51 PM   #1
pmcg
Default brake drums early ford
Hi All,
Restoring a one-off built on a 1950's Kurtis chassis which came with Ford running gear. Need to find replacement front drums but can't identify. 12" dia, 2" shoe, 4.5" bolt centres, 3.25" hub, 3.75" offset. Goes on and early ford kingpin style spindle. Here's what it looks like. Any help would be greatly appreciated.
Paul.
pmcg is offline   Reply With Quote
Old 02-07-2019, 06:10 PM   #2
skidmarks
skidmarks's Avatar
Default Re: brake drums early ford
Looks like a 40 ford with the hub on the Inside thats had the bolt circle redrilled
skidmarks is offline   Reply With Quote
Old 02-07-2019, 06:21 PM   #3
pmcg
Hi Skid,
The outer holes are for rivets. The drum was riveted to the hub - don't know why that would be necessary but that's what's there.
Old 02-07-2019, 06:53 PM   #4
cas3
plain ol ford drum. these guys make the best new ones http://www.bolingbrothers.com/brands...-Products.html
Old 02-07-2019, 07:06 PM   #5
skidmarks
skidmarks's Avatar
Originally Posted by pmcg View Post
Hi Skid,
Sounds like a chevy drum. Do you have a picture of the hub?
Chevy brakes on I beam ford axles was a swap at one time but it used the chevy spindle but you had to cut the axle boss down
Old 02-07-2019, 08:04 PM   #6
TJ
TJ's Avatar
Looks like that to me too./
Old 02-07-2019, 08:08 PM   #7
pmcg
Here's the hub. Starting to look like maybe the hub was originally 5.5" bolt centres that was changed to 4.5" centres for some reason?
Old 02-07-2019, 08:25 PM   #8
JSeery
JSeery's Avatar
Yep, must have wanted to fit a 4.5 inch rim size.
Old 02-07-2019, 08:51 PM   #9
Bob C
Hi Skid,
I'll bet they weren't rivets they just cut the original swaged studs
flush with the drum and redrilled for the smaller circle.
Bob
Old 02-07-2019, 09:32 PM   #10
pmcg
You got it Bob. Thank you everyone for the help. Paul.
Old 02-08-2019, 11:58 AM   #11
JM 35 Sedan
JM 35 Sedan's Avatar
Bob
Bingo to Bob!
John
Old 02-08-2019, 06:05 PM   #12
cas3
dont we get to see a picture of the old racer ?
Old 02-08-2019, 06:15 PM   #13
Andy
delete
Andy is offline   Reply With Quote
