Old 02-02-2019, 07:05 PM   #1
1930artdeco
1930artdeco's Avatar
Default head wedges
Hello,
I just popped the head up a little bit but need wedges to finish the job. Where should I go or should I make some from hard wood?
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 02-02-2019, 08:52 PM   #2
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
Default Re: head wedges
Yes, make them from h/wood. Take your time and don’t pinch your fingers. As soon as you get it a little up, slide some blocks under it. It can flatten your fingers
Jacksonlll is offline   Reply With Quote
Old 02-02-2019, 10:29 PM   #3
1crosscut
1crosscut's Avatar
Remember not to drive the wedges into the valves.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 02-03-2019, 12:34 AM   #4
1930artdeco
Yep have pinched the fingers the last time. Well off to buy some oak or something similar tomorrow.
1957 Country Sedan
Old 02-03-2019, 12:57 AM   #5
Dodge
You can also buy plastic shims at Home Depot
Dodge is offline   Reply With Quote
Old 02-03-2019, 08:52 AM   #6
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
I sliced a THIN meat cleaver into 4 wedges & got it off!
Bill Tricky
"THE ASSISTANT GURU OF STUFF"
