Old 01-05-2019, 05:37 PM   #1
Deuce Man
Deuce Man's Avatar
Default Model a 5 speed
Is there a way to make a stock model A speedometer work with an s- 10, 5 speed transmission? Thanks Rich
Deuce Man is offline   Reply With Quote
Old 01-05-2019, 06:18 PM   #2
Bob C
Default Re: Model a 5 speed
Doesn't it drive from the rear axle pinion?
Old 01-05-2019, 07:02 PM   #3
Davew
Davew's Avatar
Yes, you need a non world class tail shaft. Maybe need a little longer speedometer cable.
Davew is offline   Reply With Quote
Old 01-06-2019, 09:29 AM   #4
brokenspoke
I Used a 4x4 5 speed and kept the torque tube...
brokenspoke is offline   Reply With Quote
Old 01-06-2019, 12:17 PM   #5
Jim Brierley
an adapter such as brokenspoke speaks of is available thru Millerhi-speedheads.com
Jim Brierley is offline   Reply With Quote
Old 01-06-2019, 05:29 PM   #6
Gene F
Gene F's Avatar
I talked to a man that put in the 5-speed, and wishbone. He said he'd never do it again, it doesn't pick up that much speed. I was surprised to hear that.
Gene F is offline   Reply With Quote
Old 01-06-2019, 09:16 PM   #7
Jim Brierley
I have one in my Vicky, and really like it. It shifts like a dream, has well-spaced ratios, etc. Mine is open-drive as it was easier to install, for me. They are available in a wide assortment of ratios.
Old 01-06-2019, 10:00 PM   #8
Deuce Man
Deuce Man's Avatar
So Jim, what did you do for a speedometer? thanks, Rich
Old 01-06-2019, 10:18 PM   #9
Dick Steinkamp
Dick Steinkamp's Avatar
Actually, an early world class trany will still have the mechanical drive speedo. The later ones have the electronic drive for the speedo and will not work with a mechanical speedo like the Model A.
The plastic driven gear in a T5 is common in most early GM tranys...including automatics. There are almost an infinite number of different tooth configurations available to dial in the accuracy of your speedo. I have a WC T5 in my MGB with a Rover aluminum V8 and Camaro T5 and the original MBG speedometer is dead nuts on with a GPS.
You will probably need a custom speedometer cable with the Model A end on the speedo side and the Chevy end on the trans side. Any speedo shop can make one up cheaply.
All steel from pedal to wheel
Dick Steinkamp is offline   Reply With Quote
Old 01-07-2019, 01:03 PM   #10
Jim Brierley
Duece Man, Mine is an early trans with a mechanical gear drive on it. Speedo reads way fast so I will put a GPS drive on my aftermarket, electric speedo.
Old 01-07-2019, 01:50 PM   #11
Davew
Davew's Avatar
I wasn't aware early world class and mechanical spedo I wasn't able to check mine closely against a gps because the salted roads but I was told that there are enough gear sets to adjust it. Mine is open shaft also and really like it.. very smooth shifting up and down. gears are very road friendly. kinda pricey but worth it.
Old 01-07-2019, 03:23 PM   #12
Dick Steinkamp
Dave,
Although the WC T5 is an all round better trany (bearings instead of bushings) it is really not needed in our low power Model As. The non WC trany will do just fine and are a lot cheaper than the WC model. Glad you are enjoying yours!
