Old 11-12-2018, 08:37 PM   #1
walkerlakeprinter
walkerlakeprinter's Avatar
Default How to fit a spare tire brace
How does one go about shortening a spare tire brace A163ABR (Mike's "A" Ford-able) or A-163-S (Snyder's) to support the rear carrier in a 1929 Coupe? Has anyone tried that.....or figured out another method to secure the upper bolt? Mike's says it can be used on 1928-1929 back panels, but must be shortened to fit.
walkerlakeprinter is offline   Reply With Quote
Old 11-14-2018, 02:20 AM   #2
pbishop
Default Re: How to fit a spare tire brace
I have a '31' Deluxe Coupe. I have the rear carrier spare tire mounted behind a 'rumble seat. I bought and installed the cast-iron support that connects to the upper/top bolt of the spare-tire mount and is bolted to the back floor panel under the rumble-seat. I had not problem with any clearance issues.
pbishop is offline   Reply With Quote
Old 11-14-2018, 12:54 PM   #3
walkerlakeprinter
The cast-iron support is only for the 30-31 coupes. The support I referenced says it "can" be used on the 28-29 coupes. From the picture in the catalogs, I can't figure out how it fits nor how it needs to be shortened.
Still puzzled.
Old 11-14-2018, 03:54 PM   #4
walkerlakeprinter
Attempt at attaching picture.
Old 11-14-2018, 03:56 PM   #5
walkerlakeprinter
This is the Spare Tire Brace I was referencing. I can't figure out how it would fit my 1929 Coupe with rumble seat and rear spare tire carrier. Has anyone seen one of these modified to fit a 1928 or 1929 Coupe?
Old 11-14-2018, 09:01 PM   #6
Vin-tin
Vin-tin's Avatar
Instead of shortening, just buy the shorter one made for 1929. Originals pop up on ebay sometimes.
1929 Coupe
1930 Coupe
1935 Ford 5 window coupe
Vin-tin is offline   Reply With Quote
Old 11-14-2018, 09:07 PM   #7
Vin-tin
Vin-tin's Avatar
This brace is part of the inner structure of the panel below your rumble lid. Not visable unless you get on your back and look under the rear of your car. You sure its not already there.
1929 Coupe
1930 Coupe
Old 11-14-2018, 09:08 PM   #8
Marvin/TN
Send a message via AIM to Marvin/TN
Just cut a section out of it and weld it back together just make sure and not take too much out
Marvin/TN is offline   Reply With Quote
Old 11-14-2018, 09:22 PM   #9
Don Turley
Don Turley's Avatar
What is the correct length for 1928-29? -- for 1930-31? Where are you measuring it?
I have one of these, but I don't know which one it is.
Don Turley is offline   Reply With Quote
Old 11-14-2018, 11:32 PM   #10
Randy in ca
Randy in ca's Avatar
I don't have exact measurements, but the taller outer panels were about 9" and the short ones about 7", with the braces probably about an inch or so shorter overall than this (i.e. 8" and 6") .
It's not totally a 28-29 vs 30-31 issue. The long ones were used on all year roadsters and 30-31 coupes. The short ones were used on all year cabriolets and 28-29 coupes. Some webpages/catalogs don't accurately reflect these applications.
I believe (but not positive) that the cast "banana" brace was also used on all rumble seat installations except for some very early 1928 vehicles.
If you still can't picture how it all goes together I can dig up some pictures or find some previous threads.
Randy in ca is offline   Reply With Quote
Old 11-15-2018, 08:31 PM   #11
Vin-tin
Vin-tin's Avatar
Here you go.
1929 Coupe
1930 Coupe
Old 11-15-2018, 11:06 PM   #12
walkerlakeprinter
Thank you! Now I can see how it fits. Again, thanks!
Old 11-20-2018, 10:59 AM   #13
walkerlakeprinter
I just saw an ad on eBay that says this piece is for Model A Coupes with trunks! Never saw that mentioned in any of the supply catalogs I have. Hmm....
I think the "banana" support is what I need with a rumble seat car.
Old 11-20-2018, 11:12 AM   #14
Oldbluoval
Oldbluoval's Avatar
Marvin/TN...It's really not that easy. The angles change a lot. Also, the shorter one has a bit more curve to it. It's hard to adjust the curve as it is probably 12-14 gauge. A torch can do wonders.
But I've done it before too.
Oldbluoval is online now   Reply With Quote
Old 11-21-2018, 02:02 AM   #15
Randy in ca
Here are a couple of links to previous threads with some pictures and info. Reproductions of both the outside and inside panels below the rumble lid are of notoriously poor quality if that's what you're working with.
https://www.fordbarn.com/forum/showthread.php?t=219580
https://www.fordbarn.com/forum/showthread.php?t=241539
