Old 09-20-2018, 02:18 PM   #1
gypsycandle
gypsycandle's Avatar
Default Replacing Top on 1930 Tudor Sedan
Upon removing the top material and the two piece rain gutters which were still in great shape: I found only one mouse hole in the top which i repaired. The chicken wire and under lying materials are still intact and in great shape.
Now my question is what type of sealant are they talking about in the instructions ,"place a bead of sealant under the rain gutter before reattaching"
Question two: what do i used to fill in the tacking holes along the gutter's path, some of the wood is rotted on the very outside (but not on the inside). I cannot replace the wood because the interior was just completed.
Any suggestions are appreciated. Coming to the end of my two and 1/2 year project now.
thanks in advance,
Michael...
I'm quickly becoming a "Specialist" in which I know more and more about less and less until I know everything about Nothing!
gypsycandle is offline   Reply With Quote
Old 09-21-2018, 12:02 AM   #2
Ed Wendell
Ed Wendell's Avatar
Default Re: Replacing Top on 1930 Tudor Sedan
Michael,
I would use some 3M or other brand of Seam Sealer, some are water soluble clean up. Should find it at an auto paint supply.
For the wood, look into RotFix (spelling) it is a two part you mix and brush on. Don't mix too much at a time.
Ed
Ed Wendell is offline   Reply With Quote
Old 09-21-2018, 10:41 AM   #3
gypsycandle
thanks ED i will check into it...
Old 09-21-2018, 10:49 AM   #4
Tacoma Bob
Tacoma Bob's Avatar
Several us have had good success with a product called BIG STRETCH. Worth a look see.
Tacoma Bob is offline   Reply With Quote
Old 09-22-2018, 04:12 PM   #5
Rex Perry
Michael,
Be very careful with the epoxy wood preservative materials. Stuff like Get-Rot is very liquid, about like water, and could find its way onto the interior panels. If the outside edge of the wood is in question, use longer fasteners to secure the new top and rain gutters. A good seam sealer from 3M would work well; I would stay away from silicone.
Lay the top material out on the car and let it set in the hot sun for some time. The top needs to stretch for it to look good. You will need some helpers...
Good luck,
Rex
Rex Perry is offline   Reply With Quote
Old 09-22-2018, 04:13 PM   #6
2manycars
2manycars's Avatar
I have used a seam sealer called Sikaflex. Come in black and other colors.
Bill
www.brauchauto.com
2manycars is offline   Reply With Quote
