Old 09-10-2018, 08:19 AM   #1
31Abone
31Abone's Avatar
Default 32 Ford B PU ignition drop rebuild
Took out the steering column,not sure how to drive pin out to remove from column ? have key and it turns and trys to lock but lever broke off and no wires hooked up ...anyone rebuilding these units ? saw somewhere the name Baxter ? contact info also steering box needs repaired also .. any help much appreciated..trying put back as original but PU has been abused thru the years...need other parts also...Spencer
31Abone is offline   Reply With Quote
