Old 08-18-2018, 04:18 PM   #1
Leonard
Default Signal lights
I installed signal lights on my 1938 Ford Fordor Delux Sedan. All lights work but flash erratically . How do I fix this problem?
Leonard is offline   Reply With Quote
Old 08-18-2018, 05:10 PM   #2
weemark
Default Re: Signal lights
could it be an earth problem? I find a lot of electrical faults can be traced back to a bad earth.
weemark is offline   Reply With Quote
Old 08-18-2018, 07:03 PM   #3
TJ
TJ's Avatar
Check all your grounds. Sounds like a classic example of poor grounding.
Old 08-18-2018, 07:06 PM   #4
adileo
adileo's Avatar
Are any of the bulbs LED?
Thanks
Andy
1952 F1
adileo is offline   Reply With Quote
Old 08-18-2018, 07:12 PM   #5
Step-down
Step-down's Avatar
I used a Napa flasher but my AV8 is 6 volt .
"I can't cry as long as I know the Lord has risen "
Step-down is offline   Reply With Quote
Old 08-18-2018, 10:25 PM   #6
Graeme / New Zealand
Graeme / New Zealand's Avatar
Sometimes it's the flasher. If it is 6v pos earth use the tridon/novita LL535 ...USA made and avoid the Chinese made silver tin can LL535
GB
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
Old 08-18-2018, 11:01 PM   #7
slowforty
slowforty's Avatar
Some times the Bulbs are too small to activate the Flasher. Try a larger size.
slowforty is offline   Reply With Quote
Old 08-19-2018, 11:01 AM   #8
ABento
The NAPA flashers are junk, they are transister style, you want a mechinal type that we used to get, get with Northwestern Auto parts in Grand Rapids Mi and ask for a mechinal they will work,I just went thru this on a 34 truck.
ABento is offline   Reply With Quote
Old 08-19-2018, 06:19 PM   #9
edhd58
edhd58's Avatar
my setup is 12v but i had to get a heavy duty non-transistorized unit to make it flash correctly
edhd58 is offline   Reply With Quote
Old 08-20-2018, 07:29 PM   #10
Leonard
Would you happen to know the exact name or part no. for the flasher and contact info for Northwestern Auto Parts?
Old 08-30-2018, 03:50 PM   #11
Leonard
Hi, I want to thank you for your advice to get a mechanical flasher from Northwestern Auto Parts. I purchased one, installed it and my signal lights work perfect. Thank you.
Old 08-31-2018, 04:27 AM   #12
fortyonerag
fortyonerag's Avatar
I had the same problem on my 41. Changed the flasher and all was OK
fortyonerag is offline   Reply With Quote
