Old 07-21-2018, 03:28 PM   #1
kimeccles
kimeccles's Avatar
Default wheel rim liners glue a bit, or no?
Just got wheels painted. Put on new aftermarket rim liners, the rubber band effect is sort of weak and they can be shifted around fairly easy and sort of slide up the sides some.
They are 19 inch wheels, and the actual liners say 17/18 on them which considering they go in the dip might be OK?
Are these supposed to have a little adhesive to hold them in place so the valve stem hole stays or am I just paranoid?
The ones on the wheels before painting took work to get them off and acted like they were partially glued.
thanks
kimeccles is offline   Reply With Quote
