Old 07-16-2018, 04:06 PM   #1
RRW
Send a message via Yahoo to RRW
Default Glass bowl gaskets....
I just drained my fuel for a 3 month storage by running it dry.
Noticed a little sediment in the bottom of the glass bowl as I removed it.
Turns out the 'dirt' was from the deteriorating neoprene gasket.
My A runs fine with no fuel problems.
What would be the better replacement:
1. Cork gasket
2. Neoprene gasket
3. Micro paper filter kit 2pk with filter and gasket attached.
RRW is offline   Reply With Quote
Old 07-16-2018, 04:47 PM   #2
jw hash
jw hash's Avatar
Default Re: Glass bowl gaskets....
cork is the best all around.
jw hash is offline   Reply With Quote
Old 07-16-2018, 08:12 PM   #3
Doug_Knutson
Damn - I had a course cork gasket sheet -cut out a donut and installed Leaked like a sieve as the cork was far to porous ... lesson learned - buy a proper gasket and it
will work like magic
Doug_Knutson is offline   Reply With Quote
Old 07-16-2018, 08:33 PM   #4
Purdy Swoft
Purdy Swoft's Avatar
Glass bowl gaskets was one of the main reasons that I changed to the cast iron sediment bulb filter . It works good and its purty too !
Old 07-17-2018, 07:29 AM   #5
leo
leo's Avatar
I agree with Purdy, glass bowl gaskets are a PITA, having said that I know that many owners swear by them and not at them....go figure.
leo is offline   Reply With Quote
Old 07-17-2018, 08:03 AM   #6
RRW
Thanks.
I still have my original cast-iron bowl and may re-install it.
I've had my A since 1963 and it had no problems when I replaced it with the glass bowl 3 years ago.
Old 07-17-2018, 10:40 AM   #7
Purdy Swoft
I feel that some prefer the glass bowl filter because they can see the trash as it builds up in the glass bowl . I really don't need to see the sediment , I just know that after a while that it will be there . The cast sediment bowl is easy to take apart and clean . The lead gasket will last for years. I have found that the cork or neoprene gasket used with the glass bowl must be replaced anytime that the glass bowl is removed or it will leak . I had one of my model A's to catch on fire , back in 1962 because of a leaking bowl gasket . I also prefer the quaint look of the cast iron sediment bowl .
Old 07-17-2018, 06:32 PM   #8
DHZIEMAN
Cork, without question!
DHZIEMAN is offline   Reply With Quote
Old 07-17-2018, 07:38 PM   #9
larrys40
Purdy, you are incredibly informative AND FUNNY!!
Larry Shepard
larrys40 is offline   Reply With Quote
Old 07-17-2018, 09:23 PM   #10
Purdy Swoft
Thanks Larry !!! I'm just having a little fun .
