Old 06-04-2018, 04:24 PM   #1
djuby1
Default 1931 Model Victoria installation of the double arm regulator
How do you install the double arm regulator in the door. I needed to shem the glass channel so the window did not jam. was able to get everything out and cleaned up but I am having problems getting the regulator back in with the arms in the slide mechanism. Any advice would be hepful.
djuby1 is offline   Reply With Quote
