#1 |
I am going to get an A manifold punched for my Model B carb. I am just curious if I reattach an A carb, will it matter? Or, will the larger throat opening cause issues with turbulence and vacuum?
Thanks, Mike
1930 TownSedan (Briggs) 1957 Country Sedan |
#2 |
It won't cause any problem at all. I'm doing it right now as my B carb. is in for repair so I'm running an A carb. on a bored out A manifold
#3 |
Hi Mike, that what I have on my slant T/S. It's run fine for years with a Tillotson and now Marvel carbs.
Make sure the shop references off the bore and not the flange. |
#4 |
According to the Piranios dyno sheets site , a bored out model A intake manifold will help, even if a model A zenith carb is used .
#5 |
I agree with all above. Bored out A manifold with Zenith A and B, Tillotson and running a Marvel. All worked well and like the Marvel right now, one with accelerator pump and one with out. All work well.
#6 |
Mike
