#1 |
find in a french swap meet this bosch generator . script on the body RJH 130/12 2000RS279P
do you know this generator and what are the parts available ( regulator ) i think it's a 12 volts generator https://www.fordbarn.com/forum/attac...1&d=1520874725 |
#2 |
Just check how the field coils are connected.
If one side goes to case and other to Field connection Fords Relay should work. For the Bosch type on there take a look at beetle stuff. |
#3 |
That looks like the one I got on a German flathead, which would make sense. Hard to tell from your photo, but mine was a very large unit, much bigger than what we are used to. Mine was 12V. Is your generator a big one or more normal sized?
#4 |
Mart I glad you qualified that last sentence with the word "generator"
![]() GB
"you can't make honey out of dog sh*t" "You're a long time looking at the lid" |
#5 |
Yeah, I know, I had to rewrite it twice so it didn't sound rude.
#6 |
#7 |
130-12-2000 -----130 watt, 12 volt,2000 rpm --is it 2 brush, or 3 brush, how many terminals, ---without seeing how it is internally wired I can only guess based on other bosch generators I have worked on, most likely a regular USA Ford regulator won't work, the ford regulator puts power to the field, most Bosch units the regulator grounds the field
the "regulator" (from what can be seen in the pictures) looks like it is just a cutout, take the cover band off and see how many brushes If it is 2 brush you need also to get a regulator for 130 watt |
#8 |
thank you
