Old 02-21-2018, 04:14 PM   #1
19Fordy
19Fordy's Avatar
Default 3.3 ohm, 12V Coil Question on Unilite Ignition
Is is ok to use this coil with a Mallory Unilite breakerless Ignition system.
My goal is to eliminate the ballast resistor and prevent the electronic module from overheating and burning up.
https://www.ebay.com/itm/IGNITION-CO...72.m2749.l2649
I think I read somewhere on HAMB that 3 ohm coils can be used on 4 and 6 cylinder engines only.
Thank you. JIM
