Old 02-07-2018, 05:12 PM   #1
37Flat
37Flat's Avatar
Default Intake Manifold Swap
When I got it, my ’37 had a 24 stud flathead that I believe was a ’48. It was not fixable, so I now have a ’37 221. Question is, would there be any advantage to using the ’48 intake (performance wise) on the ’37 block. I’m building it to drive, not show, although it is stock.
Chris
Chris
KNKStudio221.com
37Flat is offline   Reply With Quote
Old 02-07-2018, 06:01 PM   #2
ford38v8
ford38v8's Avatar
Default Re: Intake Manifold Swap
Chris, There are just a couple differences to consider: One is the third hole (heat riser) in the 1937 carb mount, which is not compatible with the use of a 94 carb. The other is the diameter of the vacuum port for the Trico wiper motor.
Alan
Old 02-07-2018, 06:55 PM   #3
37Flat
37Flat's Avatar
Ok, thanks Alan. As I have a 94 carb, I guess I'll work with the "48 intake.
Chris
Chris
KNKStudio221.com
