#1 |
I could not find anything in the red book.
What would you torque the two rear u shaped hanger spring bolts to. Or would you just tighten them up? ![]() |
#2 |
Tighten them but do not install cotter keys yet. Use a 1/2 inch drive socket and a braker bar and put some heft into it.
To insure everything is well seated in, run the car around for a few miles, and re-tighten. repeat three or four times and then install the cotter keys. That is what I would do. Chris W. Last edited by CWPASADENA; 02-01-2018 at 08:05 PM. Reason: ELABERATION, TYPO |
#3 |
old31,
The spring shop that would re-arch springs suggested after 200 miles to re-torque the spring clamps. Just went thru the same exercise with a new front spring. Removed the clamps and lower plate, tightened the center bolt and reinstalled the lower plate and re-torqued. One less on the winter 'to do' list. Winter will end, right ?? |
#4 |
