Old 01-29-2018, 09:17 PM   #1
my40ford
Default 40 carb question and temp sensors
Have a 40 fordor deluxe and supposedly a 80hp engine but the carb on it says model 92...is this the wrong carb for the 80hp motor. Also have the original temp sensors and wondered if they would still be good or should i get 2 new ones? Thanks for any help!
my40ford is offline   Reply With Quote
Old 01-29-2018, 09:35 PM   #2
alanwoodieman
Default Re: 40 carb question and temp sensors
should only be one temp sensor for 40, carb should say 94 on the carb-how about a picture?
alanwoodieman is offline   Reply With Quote
Old 01-29-2018, 09:38 PM   #3
flatjack9
flatjack9's Avatar
That carb is for a 60 hp. The correct one would be a 91-99 which is a Holley 94.
Old 01-29-2018, 10:18 PM   #4
my40ford
The car sat in a barn for 60+yrs. Engine was rebuilt but had 2 temp sensors in it and of course the carb i believe is the wrong one. In my findings i agree it should only have 1 temp sensor. Im trying to upload pic but may gave to email it
Old 01-29-2018, 10:18 PM   #5
my40ford
The heads are also 24 studs
Old 01-29-2018, 10:23 PM   #6
drolston
drolston's Avatar
Two temp sensors is correct on a '40 flathead. Don't replace either until you are positive it has failed. The commonly available replacements are a crap shoot.
Old 01-29-2018, 10:28 PM   #7
Ken/Alabama
Ken/Alabama's Avatar
I beg to differ ! Two temp sensors is NOT correct on a 40 ! Only one in the left head.
Ken/Alabama is offline   Reply With Quote
Old 01-29-2018, 11:11 PM   #8
deuce_roadster
deuce_roadster's Avatar
What Ken said x2.
The threaded hole on the pass side head is for the hot water heater shut off valve.
Old 01-29-2018, 11:31 PM   #9
JSeery
JSeery's Avatar
You can email the photos you what posted and I'll post them for you. [email protected]
