Old 01-22-2018, 07:09 PM   #1
Neil Mylar LakewoodCA
Neil Mylar LakewoodCA's Avatar
Default Help. What size gear shift knob insert do I need?
I have a later Ford gear shift knob that i want to use on my 1929 Tudor stock trans shifter.
The later Ford gear shift knob has a larger threaded hole.
Does anyone know what size insert I would need to make up the difference?
Thanks, Neil
Neil Mylar LakewoodCA is offline   Reply With Quote
Old 01-22-2018, 07:14 PM   #2
Default Re: Help. What size gear shift knob insert do I need?
Old 01-22-2018, 07:41 PM   #3
Nathan_1929
Nathan_1929's Avatar
Determine the thread of your later knob. The A thread is 5/16-24.
You might even get lucky and buy a standard thread insert that matches both, yours on the outside and 5/16-24 on the inside.
Nathan - 1929 Closed Cab Pickup, 1929 Tudor, 1930 Coupe, 1941 Pickup - Vintage BMW Motorcycle Collector/Mechanic
Nathan_1929 is offline   Reply With Quote
Old 01-22-2018, 09:02 PM   #4
Afordman31
Afordman31's Avatar
The knob on my Speedster had a big metric thread. I went to the hardware and bought a bolt the same size, chucked it in my lathe and drilled the center with a tap drill then threaded it 5/16-18......the knob came with a metric nut so that let me turn the knob where I wanted it, then locked it in place. It is a #3 pool ball.
Afordman31 is offline   Reply With Quote
Old 01-22-2018, 09:34 PM   #5
NCRebel
NCRebel's Avatar
I once took a chrome "T" Holly shift handle and put it on a 68 Ford Mustang floor stick. I used two part epoxy for a filler and inserted a screw the same size (thread count and length) into the handle. After curing for two days, I was able to screw the handle onto the shift post.
To line up the handle to where I wanted, I dropped some rubber cement into the hole before I attached the knob. The knob was still there when I sold the car in 1975.
NCRebel is offline   Reply With Quote
Old 01-22-2018, 11:58 PM   #6
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Fill the hole with J.B. WELD, oil the shifter threads, push it on & wipe the excess. Let it cure for 24 Hours.
Bill Quickshifter
"THE ASSISTANT GURU OF STUFF"
Old 01-23-2018, 05:36 AM   #7
Bruce of MN
Bruce of MN's Avatar
Do either of these fit?
http://www.essentracomponents.com/en...d-size=5-16-24
Bruce of MN is offline   Reply With Quote
Old 01-23-2018, 02:33 PM   #8
sphanna
sphanna's Avatar
I did exactly as what Bill Williamson did. I used an old household Door knob and filled the square hole with JB Weld. Then I tapped with 5/16-24 or what ever threads, can't remember for sure. Works great for years.
Steve Hanna, Polk City, IA
sphanna is offline   Reply With Quote
Old 01-25-2018, 01:18 AM   #9
I found out that an insert would need to be 3/8-24 by 5/16-24. I check several insert websites, but they don't offer that size.
Does anyone know of a place I could get that size insert.
If I cannot find an insert I will use the jb-weld method that has been suggested.
Regards, Neil
